Date/Time: Wed, 15 Jan 2025 13:06:51 +0000
Most Studies not visable
View Count: 1493
[2017-08-14 17:10:21]
User683844 - Posts: 24
I just started a trial and most studies are not visible.
I've attached two images. One is of the studies I see available and the other is of the studies it seems I should see available.
Please advise.
Thanks!
imageIMG_3684.JPG / V - Attached On 2017-08-14 17:08:00 UTC - Size: 4.87 MB - 313 views
imageIMG_3685.JPG / V - Attached On 2017-08-14 17:08:24 UTC - Size: 2.02 MB - 286 views
[2017-08-14 17:30:03]
There is a file missing with the installation. Perform the installation again by using this link:
https://www.sierrachart.com/downloads/SierraChartFileDownloader.exe
And we recommend using the default installation folder instead of modifying it.
[2017-08-14 20:23:17]
Does this have something to do with Wine/Mac?
[2017-08-14 20:24:20]
It is possible but we would not have expected this.
It is something that rarely we hear about.
[2017-08-14 20:49:39]
Nevermind, your suggestion worked. Thanks!
[2017-08-15 11:56:42]
The problem is back. When I open via the Wine installer, all the studies are available. However, when I open from the regular desktop icon, they are not.
My OS is the most recent-I keep everything up to date.
Maybe I should try Parallels?
[2017-08-15 14:03:06]
What is happening is that the SierraChartStudies.dll file becomes inaccessible in some way.
Date Time Of Last Edit: 2017-08-15 14:04:01
[2017-08-15 19:44:28]
Ok, as long as I open from the pictured file, everything loads.
imageIMG_3695.JPG / V - Attached On 2017-08-15 19:43:42 UTC - Size: 4.46 MB - 308 views
[2017-08-16 15:14:04]
Now my trial data is an hour behind. Do I have a new problem?
[2017-08-16 16:17:04]
Tell us one of the symbols you are referring to.
[2017-08-16 17:24:43]
I'm only looking at ZB at this point but it has resolved!
[2017-08-16 20:20:05]
In regards to this, refer to step 14 here:
Sierra Chart Historical Data Service: Setup Instructions
