Date/Time: Wed, 15 Jan 2025 12:39:21 +0000
Large Volume Trade Indicator in Package3
View Count: 748
[2017-08-14 13:24:00] |
Jezz - Posts: 33 |
Hi I'm trying to setup Large Volume Trade Indicator without success. The trades shown on T&S above threshold are not marked by indicator as shown in a short attached clip. Is this the proper performance? Does it really work in package3? Thanks in advanca |
LVTI.mp4 - Attached On 2017-08-14 13:22:53 UTC - Size: 255.05 KB - 317 views |
[2017-08-14 13:36:16] |
Make sure Sierra Chart is set for a tick by tick data configuration: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-14 14:04:41] |
Jezz - Posts: 33 |
Thanks. Now everything is fine. Even my previous request is now solved with this Thanks again |
