Date/Time: Wed, 15 Jan 2025 12:40:24 +0000
Live account
View Count: 1025
[2017-08-14 12:12:40] |
User837270 - Posts: 6 |
Hello support, I use SierraChart for 3 months and so far I am satisfied, I would like to open an account and start trading live, but information contained therein is here too and with my English I would translate everything for a week, I was a bit confused and need advice. I understand, that to enter orders I have to open an account with some broker and I can choose from the ones listed on this page - Supported Data and Trading Services . I would like to open an account with a maximum of 3000 $ (I know some brokers can open an account Up to 10 000 $, which is too much for me), at the same time I need low commissions, high quality data and generally all the fees as low as possible. Can you recommend me something and how to proceed with the connection so that everything works please? Thank you very much. Regards, Simona |
[2017-08-14 12:28:19] |
What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-14 12:28:28
[2017-08-14 14:20:15] |
I want to trade e-mini futures specifically Dow Jones, S&P and NASDAQ.
[2017-08-14 17:11:47] |
We recommend using a broker supporting CQG. Refer to this page: CQG Trading Platform Service The largest broker we work with handling CQG is AMP. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-15 14:18:39] |
Ok, so for live trading and to buy or sell orders I need broker or clearin firms supporting CQG?
[2017-08-15 17:01:07] |
Yes, this is a correct understanding. CQG is one of the choices. There is also Interactive Brokers: Interactive Brokers Trading Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-15 17:01:34
