Date/Time: Wed, 15 Jan 2025 13:06:43 +0000
Bar Time Duration Indicator
View Count: 1464
[2017-08-14 04:26:14] |
User4000 - Posts: 8 |
Hello I am unable to get the 'bar time duration' indicator to work with Point & Figure charts. Thank you for you help Sincerely, User775874 Date Time Of Last Edit: 2017-08-14 06:13:19
[2017-08-14 09:32:19] |
Are you using the Point and Figure Chart Study or the Bar Period Type >> Point and Figure Bar setting in Chart >> Chart Settings? You must use Bar Period Type >> Point and Figure Bar. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-14 09:32:47
[2017-08-15 06:49:05] |
Thank you for your reply, But it still does not work :( |
[2017-08-15 07:09:13] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
