Date/Time: Wed, 15 Jan 2025 13:03:47 +0000
How to set indicators to not affect scale
View Count: 1219
[2017-08-14 00:53:12] |
12VMan - Posts: 45 |
Hi, I want to use MA Envelopes to reflect points of resistance. Some are extreme and would not be seen on a chart with "normal" price movement. When I add them, the chart's price axis expands to include all of the envelopes. How do I prevent this from happening? I want the indicators there, but I don't want them to impact the chart's price scaling. Thanks for the help, Brandon |
[2017-08-14 02:47:00] |
binaryduke - Posts: 373 |
Right click the price axis and set the Constant Range parameter to a value that you require and set the scale settings to Constant Range.
[2017-08-14 09:35:43] |
Refer to the documentation here for this: Chart Scale and Scale Adjusting: Basing Scale Only on Price Bars The answer given in post #2 does not make sense to us. And would not solve the problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-14 09:36:10
