Date/Time: Wed, 15 Jan 2025 13:00:51 +0000
Spreadsheet Rounding to Tick Size
View Count: 1069
[2017-08-13 09:25:19] |
User787778 - Posts: 142 |
In a spreadsheet, how does one round, a calculated value, in the Bond(ZB), to a tick size of 1/32. Thanks in advance. |
[2017-08-13 13:48:45] |
Sawtooth - Posts: 4151 |
This is how I do it: 1) Round the ticksize to remove any floating point errors, e.g. in H21: =1/ROUND(1/J21,0) 2) Reference H21 using the MROUND function: =MROUND(calculatedvalue,$H$21) |
[2017-08-13 17:46:54] |
We will add this to the documentation.
[2017-08-13 19:04:24] |
Thank you Tom
