Date/Time: Wed, 15 Jan 2025 13:06:53 +0000
Study Not Displaying
View Count: 706
[2017-08-12 23:42:49]
User104854 - Posts: 457
I'm having an issue with the color bar based on alert study. I want it to display while the bar is being created on the high and/or low of the bar. I'm using 3 tick reversal bars. I'm using a simple formula for the low which is '=BVAP(L,0)>200'. I also have one for the high which is '=AVAP(H,0)>200'.
The one for the high works fine. When the ask volume hits 200 the study displays right away while the bar is being created. The one on the low is not working. It seems as if there is a glitch within the program that is not recognizing the bid volume at the low while the bar is being created.
Can you check this out please and/or help with a solution?
[2017-08-12 23:49:56]
It seems to be happening when the LAST price equals the LOW during the creation of the bar. It isn't displaying. Then when it moves up a tick from the low it will display.
[2017-08-13 15:41:56]
We will look into this. Looks like something we need to resolve or we need to understand this better and what needs to be done.
Date Time Of Last Edit: 2017-08-13 15:42:39
