Date/Time: Wed, 15 Jan 2025 13:09:34 +0000
Candlestick - Width adjustment (unable to apply edit)
View Count: 2609
[2017-08-12 22:07:18]
User424091 - Posts: 3
Hi Guys,
When I go to Graphic Settings on the chart and choose "Other" I see the input "Candlestick Width %". I am able to change the value, but it does not adjust the candlestick once I hit apply. I have turned off the box for "Use Global Graphic Settings instead of these Settings".
Can you please advise what I need to adjust to get change to apply? I notice the options on the right had side of "Other" - Color entire OHLC... Color Candlestick High-Low... Draw Bid... are all greyed out. I included a screenshot (upload via SnagIt).
imageasierra.png / V - Attached On 2017-08-12 22:06:09 UTC - Size: 69.17 KB - 344 views
[2017-08-12 22:18:33]
We see no problem with this. This is very straightforward and reliable.
Are the chart bars displayed as Candlesticks? What did you set the width to?
This is going to be the case for the Graphics Settings window for the chart.
Date Time Of Last Edit: 2017-08-12 22:19:04
[2017-08-13 14:20:26]
Yes, the charts are displayed as candlesticks. I am attempting to reduce the width of candlestick. When I enter the lower value ie. 50%, 40% it accepts the value in the box, but there is no change to the candlestick' width after I hit the "Apply" button. Thank you for your assistance.
[2017-08-13 14:23:47]
Therefore, this must be correct based on the calculations and the current spacing between the chart bars.
Increase the spacing between the chart bars to lets say 20 pixels or more, and then change the percentage. Try changing the percentage to 1.
[2017-08-13 21:37:36]
Guys,
HUGE thanks! This worked. Very pleased :)
