Date/Time: Wed, 15 Jan 2025 12:54:57 +0000
Horizontal Line Posting
View Count: 786
[2017-08-12 19:04:46] |
User806639 - Posts: 32 |
How can I move the Horizontal line option under the tool setting to the TC1 icon on the too bar. I am trying to set up a one click performance to be able to set a support or Resistance Line.
[2017-08-12 22:49:45] |
TC 1 is a Drawing Tool Configuration button. This documentation here explains drawing tool configurations: Chart Drawing Tools: Drawing Tool Configuration There are also Control Bar buttons that can select a particular Drawing Tool and configuration with a single step: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-12 22:50:58
