Date/Time: Wed, 15 Jan 2025 12:38:07 +0000
Opening Range - Extended Lines
View Count: 1329
[2017-08-11 14:43:15] |
lpfin123 - Posts: 59 |
Good morning, I've been able to draw an opening range using "High/Low for Time Period". The only thing I would be missing, and I've tried every Draw Style that you offer, is an extended line. I would like the opening range to be extended until the end of the day. Is this something possible? If not, is it possible to add the possibility of an extended line? Thank you for your time, |
[2017-08-11 15:19:24] |
You need to use the High/Low for Time Period-Extended study instead.
