Date/Time: Wed, 15 Jan 2025 12:44:59 +0000
question on traded price and trade window
View Count: 784
[2017-08-11 12:47:23] |
zippyzip - Posts: 293 |
is there a reason that these dont match up , running some algo tests and i know its probably a setting if you can help me out that would be great , thanks
Private File |
[2017-08-11 20:38:20] |
You need to uncheck this option: https://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#FlatToFlatAveragePriceForPosition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
