Date/Time: Wed, 15 Jan 2025 12:38:49 +0000
history trades on the chart
View Count: 766
[2017-08-11 09:59:35] |
User328593 - Posts: 3 |
is possible to view transaction on the chart as line between open and close? something like attached chart
EURUSD [M] 2 Min #1 2017-08-11 11_58_25.313.png / V - Attached On 2017-08-11 09:59:21 UTC - Size: 84.82 KB - 316 views |
[2017-08-11 13:33:10] |
Yes, refer to: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
