Date/Time: Wed, 15 Jan 2025 15:26:26 +0000
ACSIL study data
View Count: 906
[2017-08-11 06:23:46] |
User563013 - Posts: 11 |
I would like to grab study data from a chart that is created by a separate custom .dll This is the way that I think it would work: Create a chart and use a sc.GetStudyArray function to get the ID and copy in the data Is there a way to get the study information directly from or call the .dll without creating a chart? |
[2017-08-11 13:37:14] |
Refer to the documentation here for this: ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function Is there a way to get the study information directly from or call the .dll without creating a chart? The custom study does need to be added to a chart and you need to then get the study arrays. This is the only way. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-19 05:10:54] |
Is there a way to automatically add the custom study to the chart?
[2017-08-19 13:02:12] |
No, there is not.
