Date/Time: Wed, 15 Jan 2025 15:45:57 +0000
Seconds in Zigzag study time labels
View Count: 799
[2017-08-11 06:12:22] |
User50927 - Posts: 91 |
I while back I inquired about the possibility of adding an option to the Zigzag study to remove the seconds from the time labels since such precision is rarely needed and they significantly crowd up a chart. If you are not as busy these days as you were a year ago can you please look into that when you get a chance? Thanks.
[2017-08-20 01:44:20] |
We will get this done.
