Date/Time: Wed, 22 Jan 2025 23:12:04 +0000
Version 1598 slower than previous version?
View Count: 830
[2017-08-11 05:55:35]
User50927 - Posts: 91
Just wanted to let you know that after I finished installing the current version of your software on 8-11-17, the charts took significantly longer to load at the start of the program. I didn't do anything I haven't done before during upgrade and it's been months since I noticed anything like that. By the way, I typically do not connect to the data feed until after I have finished opening a chart file to avoid additional delays.
I also experienced the same problem during market replay. By comparison, the previous version was WAY faster even with twice as much data!
Thank you.
[2017-08-11 12:51:07]
What version are you comparing to and we will run a test.
Also, provide one of the Chartbooks you use following these instructions here:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
You can privately attach it.
