Date/Time: Sun, 19 Jan 2025 08:55:58 +0000
Volume At Price Threshold Alert ?
View Count: 2274
[2017-08-09 16:49:46]
Glenn Infinity - Posts: 103
I want to crate a new chart region where i get an audio alert when bar in that region is -2k or more negative, or 2k or more positive
is this the correct study, if so what settings in the "setting and inputs"?
[2017-08-09 17:17:23]
How is the -2k and +2k calculated?
[2017-08-09 17:49:31]
customer wants to use bid/ask depth bars, below is what was sent to me
the bars in the region are bid / ask depth bars. so if low of the bid/ask bar is -2k or more negative i want to get audio alert. this bar is difference between ask and bid. so for long audio alert (this is just alert to start looking what is next), ask minus bid should be -2k or more negative. example i sent you that bar low at 5.50.50 est was about -4k. so i want to be alerted when this condition occurred.
[2017-08-10 02:00:58]
Use this formula:
SG3 <= -2000
Enter this Formula on the Bid and Ask Depth Bars study.
Refer to:
Study/Chart Alerts And Scanning: To Enter an Alert Condition on a Study
[2017-08-10 18:30:35]
if we wanted it + 2000 would we use SG3 <= 2000
[2017-08-10 19:44:55]
In this case you would use SG2 >= 2000
And you can combine them:
OR (SG3 <= -2000, SG2 >= 2000)
Date Time Of Last Edit: 2017-08-10 19:45:23
[2017-08-22 18:13:20]
User526239 - Posts: 6
how do i get different audio alert when sg3 < -2000 or sg2> 2000?
[2017-08-22 18:35:11]
For different audio alerts, requires that you add another instance of the study to the chart and set a different formula on each study.
One study will use:
SG3 < -2000
The other study will use:
SG2 > 2000
Refer to:
Date Time Of Last Edit: 2018-04-05 22:09:07
[2018-04-05 05:04:33]
2garin - Posts: 184
why does not the indicator show all the alerts?
Private File
Private File
[2018-04-05 19:35:15]
Use the version 2 of this study and understand how it works:
Volume at Price Threshold Alert V2
It detects volume at individual price levels, not for the entire bar.
Date Time Of Last Edit: 2018-04-05 19:35:34
