Date/Time: Wed, 15 Jan 2025 12:55:06 +0000
Chart ticks to 1 pip
View Count: 920
[2017-08-09 16:01:27] |
User499243 - Posts: 4 |
Hello, Is it possible to chart EUR/USD to 1 pip increments. i'm not talking about displayed price. I want the actual bar to only increment in 1 pip ticks. I have changed all the settings to 0.0001 increments however the actual bar is not moving by 1 pip. Thank you |
[2017-08-09 17:09:29] |
I'm using a 200 tick chart also tried updating the tick size in symbol settings and deleting data. Nothing works
[2017-08-09 17:12:44] |
Yes you can do this with this study: Round Price Bars to Tick Size Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
