Date/Time: Wed, 15 Jan 2025 15:56:40 +0000
Snap to High/Low on TPO Profile Charts
View Count: 1272
[2017-08-09 13:28:34]
User796776 - Posts: 95
When using the Snap to High/Low on a TPO Profile Chart the result is (on a 1 tick tpo chart) a tick above or below the actual High/Low being selected.
Using the same feature on a bar/candle chart works as expected with the actual high/low being chosen.
Should the Snap to High/Low feature be consistent on a TPO chart or is there a reason for this difference?
[2017-08-09 13:36:45]
You cannot use any of the drawing tool Snap commands on a TPO Profile Chart. It is not going to work properly.
