Date/Time: Wed, 15 Jan 2025 16:14:41 +0000
current price display on chart
View Count: 1449
[2017-08-09 03:13:34] |
User630989 - Posts: 10 |
where do I find the setting to draw a line across a chart depicting the last price traded ???
[2017-08-09 03:47:04] |
This can be done with the Current Price Line study: Current Price Line Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-09 13:20:57] |
help I need better instruction ... cannot figure out how to do from the link you sent
[2017-08-09 14:10:38] |
Follow the instructions here to add the Current Price Line study to the chart: Chart Studies: Adding/Modifying Chart Studies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
