Date/Time: Wed, 15 Jan 2025 16:23:53 +0000
How to set a straight line for Support/Resistance
View Count: 2058
[2017-08-08 18:26:05] |
User942178 - Posts: 25 |
Is there an easy way to set a horizontal line on the chart? Also, is there a way to change the thickness of the line. Thank you. |
[2017-08-09 13:38:23] |
Yes use the Horizontal Line Drawing Tool: Chart Drawing Tools: Horizontal Line | Horizontal Ray | Horizonal Line Non-Extended | Vertical Line The thickness of these lines can be controlled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-09 13:38:34
