Date/Time: Wed, 15 Jan 2025 16:07:42 +0000
"unknown name"
View Count: 861
[2017-08-07 20:26:41] |
User170575 - Posts: 221 |
Hi--I notice some of my studies that access a spreadsheet dont work and now say "unknown name" in the study list. Any thoughts on what I have done and is there a way to open a previous instance of a spreadsheet? Also, is there a way to make the spreadsheet unique to the chartbook where it was created? Thx C |
[2017-08-08 07:11:10] |
Hi--I notice some of my studies that access a spreadsheet dont work and now say "unknown name" in the study list. This is very unusual. We have never heard of this. We cannot see a technical condition why this would happen.We want you to remove that study from the chart and add the Spreadsheet Study again. You will then want to set the Spreadsheet Name setting on the Study Settings window to the name of the existing Spreadsheet. Refer to: Chart Studies: Study Settings Window Also, is there a way to make the spreadsheet Yes. Use a different Spreadsheet Name for instances of the Spreadsheet Study used in a different Chartbook.
unique to the chartbook where it was created? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-08 07:11:41
