Date/Time: Sat, 26 Sep 2026 21:37:24 +0000
change grid scale settings by keyboard shortcut/chart shortcut/toolbar button?
View Count: 1310
[2017-08-06 16:22:47]
4646ed - Posts: 231
any possibility of making us able to set grid scale settings by a keyboard shortcut or chart shortcut or even by toolbar buttons? i constantly must change horizontal grid line increments from 10-20-25 and back and the only way to do it is right click on the right side price column and open scale settings and type in the numbers 10/20/25 over and over again all day long on many different charts...
[2017-08-06 19:40:26]
You can create a custom study using Control Bar buttons:
Advanced Custom Study Interaction With Menus, Control Bar Buttons, Pointer Events: Advanced Custom Study Buttons and Pointer Events
And setting this member as required:
sc.BaseGraphScaleIncrement
We probably could quickly create a study you can use in about 15 minutes for this.
[2017-08-07 06:02:43]
4646ed - Posts: 231
I dont know how to program.
Yeah. I've taken a long look at the documentation that you referred me to and I still wouldn't have a clue as to how to start...
Date Time Of Last Edit: 2017-08-07 06:45:26
[2017-08-07 15:50:44]
Here is the code to do what you want:
SCSFExport scsf_SelectScaleIncrementWithButtons(SCStudyInterfaceRef sc)
  if (sc.SetDefaults)
    // Set the configuration and defaults
    sc.GraphName = "Select Scale Increment with Buttons";
    sc.StudyDescription = "This code serves as an example of how to set the base graph scale increment by using control bar buttons.";
    sc.AutoLoop = 0;
    sc.FreeDLL = 0;
    sc.Input[0].Name = "Scale Increment 1";
    sc.Input[0].SetFloat(1.0f);
    sc.Input[1].Name = "Scale Increment 2";
    sc.Input[1].SetFloat(2.0f);
    sc.Input[2].Name = "Scale Increment 3";
    sc.Input[2].SetFloat(4.0f);
    sc.Input[3].Name = "Scale Increment 4";
    sc.Input[3].SetFloat(8.0f);
    return;
  if (sc.IsFullRecalculation)
    sc.SetCustomStudyControlBarButtonHoverText(ACS_BUTTON_1, "Change to Scale Increment 1 Input");
    sc.SetCustomStudyControlBarButtonText(ACS_BUTTON_1, "Scale1");
    sc.SetCustomStudyControlBarButtonHoverText(ACS_BUTTON_2, "Change to Scale Increment 2 Input");
    sc.SetCustomStudyControlBarButtonText(ACS_BUTTON_2, "Scale2");
    sc.SetCustomStudyControlBarButtonHoverText(ACS_BUTTON_3, "Change to Scale Increment 3 Input");
    sc.SetCustomStudyControlBarButtonText(ACS_BUTTON_3, "Scale3");
    sc.SetCustomStudyControlBarButtonHoverText(ACS_BUTTON_4, "Change to Scale Increment 4 Input");
    sc.SetCustomStudyControlBarButtonText(ACS_BUTTON_4, "Scale4");
  // wait for a button
  if (sc.MenuEventID >= ACS_BUTTON_1 && sc.MenuEventID <= ACS_BUTTON_4)
    // reset button to off
    sc.SetCustomStudyControlBarButtonEnable(sc.MenuEventID, 0);
    sc.BaseGraphScaleIncrement = sc.Input[sc.MenuEventID - 1].GetFloat();
This will be in the next release in Analysis >> Studies >> Add Custom Study >> Sierra Chart Custom Studies.
It will require you to Advanced Custom Study Buttons. Refer to:
Control Bar: Advanced Custom Study Control Bar Buttons
[2017-08-13 10:40:27]
4646ed - Posts: 231
What will the study's name be? "Select Scale Increments"?
Date Time Of Last Edit: 2017-08-13 10:41:30
[2017-08-13 13:26:49]
The name of the study is "Select Scale Increment with Buttons".
[2017-08-13 16:14:58]
4646ed - Posts: 231
Oops. That works really well -- but I guess i wasnt clear. Its the horizontal grid line increment setting i wanted to change. (Or actually having both scale increment and horizontal grid line increment on the buttons would be great.)
How would i do that? would just changing the words in the code from "scale increment" to "horizontal grid line increment" work ? or is there more?
and then how do i get the amended code into the study?
[2017-08-13 22:49:59]
This will be supported in the next release.
