Date/Time: Wed, 15 Jan 2025 13:10:35 +0000
Numbers Bars Study - Shift Text to Left
View Count: 1320
[2017-08-06 14:46:53] |
TSiSVT - Posts: 21 |
Can you add an option to be able to shift the text to the left for Numbers Bars study? Currently there is an option to center the text and , by default, it shifts to the right. I am using numbers bars along with market depth historical data study (an option to shift text to left for this study would work as well) and the numbers of each crowd each other. If I center the numbers bar text to center I still have to spread the bars too far apart to make the text of each not overlap when the numbers are 2 digits or more.
[2017-08-08 01:50:53] |
Can you provide a chart image showing what you currently see. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-08 01:51:03
[2017-08-08 02:49:01] |
If the Number Bars text (numbers) were shifted to the left then both the Numbers Bars text and the Market Depth Historical Graph numbers would both be visible without having to increase the spacing too much, therefore retaining as many bars of data as possible on the screen. http://www.sierrachart.com/image.php?Image=1502160278154.png |
[2017-08-09 17:40:10] |
We will add a left-align setting.
