Date/Time: Wed, 15 Jan 2025 12:48:36 +0000
Informations of studies
View Count: 600
[2017-08-06 13:25:11] |
User434062 - Posts: 1 |
Hi, I have a NASDAQ chart in UT 5mn with a Moving Average Simple study in 50. I have an other NASDAQ chart in UT 15mn with a Moving Average Simple study in 50. I want to know it is possible to insert in the first chart the moving average simple study of the second chart in UT 15mn. Can you explain the method.? Thanks for you help . Best regards. Styve |
[2017-08-07 02:45:25] |
You need to use the Study/Price Overlay study to accomplish this. Here is the documentation: Study/Price Overlay Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
