Date/Time: Wed, 15 Jan 2025 12:50:29 +0000
Market depth with remote data
View Count: 736
[2017-08-04 22:36:27] |
User200390 - Posts: 31 |
Primary instance uses iqfeed remote connection to second instance - works fine except that market depth indicator only plots when applied to charts in the iqfeed instance. I have "Use Non-Chart Data from Remote Instances" enabled in the primary instance.
[2017-08-05 14:28:14] |
Specifically what do you mean by "market depth indicator"? Are you referring to the Market Depth Historical Graph study? And do you need to use IQ Feed? There are going to be far less complications by using the Sierra Chart Exchange Data Feed instead. And it is a lower price as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-06 22:13:43] |
Yes, the Market Depth Historical Graph study. I may switch soon but use iqfeed to drive another tool already. |
[2017-08-07 04:06:58] |
OK we will see what we can do in regards to this.
