Date/Time: Wed, 15 Jan 2025 12:41:08 +0000
User Question
View Count: 843
[2017-08-04 17:48:04] |
Sierra Chart - Max - Posts: 5778 |
I'm having a problem with the text tool: When I make a notation using the text tool on one chart on one instrument (AUDJPY), I'm seeing the EXACT same notation appear on another chart (CADJPY) and I do not want this to happen. Can you please tell me how to prevent this from happening? Sierra Chart Support |
[2017-08-05 15:03:50] |
This is solved by disabling the option documented here: https://www.sierrachart.com/index.php?page=doc/Tools.html#ShowingDrawingsforDifferentSymbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
