Date/Time: Wed, 15 Jan 2025 12:40:50 +0000
Smaller backup size?
View Count: 1042
[2017-08-04 17:37:17]
User299240 - Posts: 2
Hello
I usually backup Sierra Chart by copying the Sierrachart folder.
Last time I noticed that the size had greatly increased to 60 GB.
How can I reduce the size?
[2017-08-04 17:40:29]
When you perform a backup, if it is not difficult, exclude the files with a scid extension.
[2017-08-04 17:58:26]
Is the only location for scid files located in SierraChart>Data?
Also I could delete the scid files in the backup / copy?
[2017-08-04 18:39:14]
Yes that is correct. They are only in the Data subfolder.
Yes you could delete the Intraday data scid files from the backup.
Date Time Of Last Edit: 2017-08-04 18:39:54
