Date/Time: Wed, 15 Jan 2025 12:46:32 +0000
Chart DOM
View Count: 918
[2017-08-04 17:05:01] |
Rino - Posts: 124 |
Hi, Can the chart DOM be utilized with Infinity or is it only available if you get Sierra charts through Sierra. Thanks as always |
[2017-08-04 17:39:46] |
In this particular case you will need a direct account: Direct Sierra Chart Account Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-04 19:38:17] |
Rino - Posts: 124 |
I think I know the answer but will ask anyway. If I go to Sierra direct will I still be able to use the crappy data provided by Transact or do I have to use Sierra's data? By the following I would guess not. "Once you have completed the steps and now have a direct Sierra Chart account, you will no longer need your other Sierra Chart account you may have had through the affiliate. You will no longer need to pay for Sierra Chart through the affiliate if you have been doing that, and can cancel with them." |
[2017-08-04 20:40:39] |
Yes, you can still use the data feed from TransAct. The TransAct data feed should be just fine.
