Date/Time: Wed, 15 Jan 2025 13:02:00 +0000
Column width
View Count: 852
[2017-08-04 14:26:04] |
User99934 - Posts: 227 |
Is it possible to maintain the Volume Profile Bars Length Relative to All Visible bars on a column in the number bars while simultaneously specifying a small width for another column?
[2017-08-04 14:30:53] |
No.
[2017-08-04 14:40:51] |
I could double the number bars on my screen if this were possible since I only need a very small portion of a column to display a color when parameters are met.
[2017-08-04 14:57:36] |
As pic shows, I could use a very small portion of a column for the color. http://www.sierrachart.com/image.php?Image=1501858439582.png |
