Date/Time: Wed, 15 Jan 2025 16:04:00 +0000
Draw Tool Configuration Enhancements
View Count: 852
[2017-08-04 13:56:32]
jakesans - Posts: 50
Hi SC,
If possible, I have a couple needed drawing tool additions/enhancements. They are listed from most to least important.
1) Ability to draw a line segment with a desired angle in degrees. I see the Gann Fan, but this is a ray and it is tedious to remove extra rays and then manually convert degrees to slope. Perhaps the Chart Calculator can include this as a configuration option, to enter an angle in degrees. Also, it would be helpful if in a similar way one could manually enter the number of bars for horizontal length. Vertical length is already included where you can set the price range.
2)Tool to draw a square or set length and width within rectangle tool.
3) Ability to set angles for triangle tool.
4) Ability to spin a drawn ellipse.
JS
Date Time Of Last Edit: 2017-08-04 13:57:56
[2017-08-04 14:34:28]
ktfroy - Posts: 85
How do you draw an ellipse?
[2017-08-04 15:36:12]
Under menu Tools > Ellipse, but I would like to be able to rotate it or probably better snap the major axis and minor axis to price points.
[2017-08-04 16:48:15]
ktfroy - Posts: 85
Thanks. I missed that - I was thinking 3 point trend line.
[2017-08-07 15:19:49]
1, 2, 4. We can do these. The first two near term. The fourth one not sure when.
