Date/Time: Wed, 15 Jan 2025 15:59:30 +0000
numbers bars calculated values source code
View Count: 2023
[2017-08-04 09:45:13]
traderacademie - Posts: 38
I want to program some other statistics derived from the volume, but I need to learn how to code in Sierra Charts. I have a professional programming background. Would it be possible to study the source code of the "numbers bars calculated values" study, so I can learn how to code custom calculated values?
Will
[2017-08-04 17:32:27]
You should not need to rely upon the source code and it is not in a format which is compatible with ACSIL.
Tell us one thing you want to do and we will explain how to do it.
Date Time Of Last Edit: 2017-08-04 17:32:34
[2017-08-07 10:04:30]
Well, I am researching different statistics, so it's not definitive. Something I would like to do is e.g. see the number of trades and volume on the bid/ask filtered by different trade sizes. And display this visually.
Date Time Of Last Edit: 2017-08-07 10:06:29
[2017-08-08 17:21:44]
Filtering is done through the Chart Settings. Refer to:
Chart Settings: Volume Filter (Chart >> Chart Settings >> Data Limiting >> Volume Filter Settings menu)
There is nothing in the Numbers Bars Calculated Values source code which would show how this is done.
There is only one set of volume filtering per chart.
Here is the ACSIL documentation to access the volume and number of trades data:
ACSIL Interface Members - Variables and Arrays: sc.BaseDataIn[][] / sc.BaseData[][]
The data you access through ACSIL is after the volume filtering is applied.
Date Time Of Last Edit: 2017-08-08 17:22:26
