Date/Time: Wed, 15 Jan 2025 12:35:33 +0000
cht file
View Count: 2092
[2017-08-03 20:49:42] |
User526239 - Posts: 6 |
how can i look at code?
[2017-08-03 20:53:53] |
The file format for Chartbook files is not provided. It would be quite a lot of work for us to document that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-03 20:57:21] |
i have custom study. i can not look at code?
[2017-08-03 21:34:13] |
We are not really clear exactly what you require. Let us know specifically what you want to do.
[2017-08-03 21:39:51] |
i just want to look at code for custom script. And change it
[2017-08-04 05:05:34] |
Refer to: https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
