Date/Time: Wed, 15 Jan 2025 12:37:46 +0000
Independent Value on Left Side of Chart
View Count: 1603
[2017-08-03 15:58:18] |
User172040 - Posts: 70 |
Where will I find more info on chart configuration where I can place an independent axis on the left hand side of the chart. Attached is the NQ with price on the right and also a NQ TICK cumulative sum study/price overlay (blue line). I want to see the cumulative tick value on the left hand side in the same format as the price data on the right hand side. Thanks
SCChart.PNG / V - Attached On 2017-08-03 15:58:05 UTC - Size: 26.52 KB - 436 views |
[2017-08-03 17:50:25] |
You need to enable the Left Side Scale: Chart Settings: Use Left Side Scale (Chart >> Chart Settings >> Scale menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-03 17:51:20
