Date/Time: Wed, 15 Jan 2025 13:00:35 +0000
removing chart millisecond display?
View Count: 925
[2017-08-02 23:53:09] |
User100997 - Posts: 3 |
Just updated to a new version, and noticed milliseconds (3 decimals) after seconds, on the chart values tool on the scale bottom. I still wanted to keep seconds active but remove milliseconds but can't seem to figure out how. Any suggestions? thank you |
[2017-08-03 04:44:27] |
We will need to add an option to remove this. Right now there is no option for this.
