Date/Time: Wed, 15 Jan 2025 12:40:07 +0000
TTM SQUEEZE INDICATOR
View Count: 4364
[2017-08-02 20:16:08] |
russellg - Posts: 10 |
IS THE TTM SQUEEZE INDICATOR BY JOHN CARTER COMPATIBLE WITH SIERRA CHARTS?
[2017-08-02 20:22:52] |
We do not think you need to use that one. Sierra Chart already has 2 Bollinger Squeeze studies, and we are actually working now on adding a third one. At least one of these is going to be the same as that one. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
