Date/Time: Wed, 15 Jan 2025 13:03:46 +0000
How do I change the height of Numbers Bars Calculated Values study table?
View Count: 2096
[2017-08-02 17:14:11] |
User583039 - Posts: 7 |
The cells in my Numbers Bars Calculated Values study table are way too high. They take up too much of my chart. How do I change the height of them? Also, which subgraph is for total number of ticks for a bar? Which subgraph is for delta (buy volume minus sell volume)? http://www.sierrachart.com/image.php?Image=1501694029455.png |
[2017-08-02 17:57:31] |
You just need to reduce the height of that particular Chart Region. Follow the instructions here: Working With Charts: Chart Window and Regions You need to use these two subgraphs: Number of Trades Ask Volume Bid Volume Difference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-04 10:24:09] |
nicktrader - Posts: 728 |
From my point of view the "problem" is your OHLC study. It could help if you set it on "Same as Region".
ScaleSettings.png / V - Attached On 2017-08-04 10:22:12 UTC - Size: 12.9 KB - 372 views |
[2017-08-04 16:28:53] |
@nicktrader My OHLC study is set on "same as region". |
[2017-08-04 16:33:14] |
okay, just an idea
