Date/Time: Wed, 15 Jan 2025 12:50:01 +0000
1592
View Count: 792
[2017-08-02 15:42:57] |
zippyzip - Posts: 293 |
HEY DID YOU GUYS UPDATE THE keyboard shortcuts as non of them work now , do i have to turn them on some were as even when i try to assign new ones they dont stay , thanks
[2017-08-02 15:57:31] |
We are working on keyboard shortcuts and the changes should not have been released. We are going to correct this in about an hour. In prerelease 1592, they will not function properly. Do not use them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-02 16:29:52] |
Prerelease 1593 is now available. It resolves this issue.
