Date/Time: Wed, 15 Jan 2025 13:05:13 +0000
Ctrl/A and Ctrl/S not available in prerelease SC 1592
View Count: 943
[2017-08-02 15:33:00] |
TechTrader - Posts: 116 |
Upgraded from SC 1587 to prerelease SC 1592. Ctrl/A and Ctrl/S functions for saving all chartbooks/single chartbook not available. |
[2017-08-02 16:01:55] |
We are working on keyboard shortcuts and the changes should not have been released. We are going to correct this in about an hour. In prerelease 1592, they will not function properly. Do not use them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-02 16:08:18] |
Also copying/pasting .scss files does not work. The formulas do not copy. Have reverted back to SC 1587 |
[2017-08-02 16:18:08] |
Also copying/pasting .scss files does not work. We are not aware of any problems with this. Tell us the specific steps you performed so we can test.
The formulas do not copy. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-02 16:18:24
[2017-08-02 16:30:08] |
Prerelease 1593 is now available. It resolves this issue.
[2017-08-02 19:54:20] |
Re post #4 To copy the whole spreadsheet contents and paste them to another spreadsheet: 1)Highlight the whole spreadsheet (the Formula Source Sheet #) - left click the far left cell above the row number indication column that also indicates which individual cell is highlighted. 2)Right click to open the spreadsheet functions. 3)Left click "Copy Value" 4)Open the destination spreadsheet. 5)Repeat 1) and 2) 6)Left click "Paste" |
[2017-08-02 20:24:51] |
You need to use Copy Formula and not Copy Value.
