Date/Time: Wed, 15 Jan 2025 13:07:22 +0000
Arrows?
View Count: 792
[2017-08-02 11:22:57] |
User56075 - Posts: 4 |
Hi can you tell me what the green up arrows are on teh attached pic? What are they and how are they calculated please?
Attachment Deleted. 2017-08-02_12-08-35.jpg / V - Attached On 2017-08-02 11:22:47 UTC - Size: 401.57 KB - 325 views |
[2017-08-02 13:28:30] |
We are not sure but you can tell through the Tool Values Window. For instructions, refer to: Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
