Date/Time: Wed, 15 Jan 2025 12:45:59 +0000
Problem with Trade Activity Log
View Count: 824
[2017-08-01 20:34:00] |
fjgaspar - Posts: 62 |
Hi, I have defined a 4.5$ round turn commission for Crude Oil on my Sierra Charts. I have done 3 trades in Crude Oil and in the Trade Activity Log, I select from Today at 0:00:00 to Today. I check Apply Comissions and I have these rows: Total Commissions: 18 Total trades: 3 But 3 * 4,5 is not 18, is 13,5 I have tried to play with different values for commissions, and every time the Total Commission doesn't match the correct calculations Is there a bug? |
[2017-08-05 13:44:07] |
Are you looking at the Trade Statistics tab of the Trade Activity Log? We will need to see a screenshot showing the top of the Trade Statistics tab along with the commission value you are seeing.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-05 13:44:23
[2017-08-06 11:29:27] |
Yes, I was looking at that but the problem doesn't occur anymore. I don't know what happened, but it ocurred in two different computers and it is solved in both. Thanks |
