Date/Time: Wed, 15 Jan 2025 13:09:06 +0000
Current Usage Time Ending Date is day after renewal
View Count: 736
[2017-08-01 16:32:53] |
User881916 - Posts: 7 |
My Current Usage Time Ending Date is tomorrow at 2017-08-02 23:59:59 UTC. My feeds just renewed on Aug 1st. I'd like to avoid a service interruption if this is what this means. Please advise. Thank you.
[2017-08-01 16:39:24] |
You do not need to be concerned about this. Tomorrow your account will automatically extend until the end of the month. We just temporarily activated it for a day before you had logged in today.
