Date/Time: Wed, 15 Jan 2025 12:45:05 +0000
Windows error code 8: Not enough storage is available.
View Count: 951
[2017-08-01 15:00:55]
User56280 - Posts: 10
similar to the user in this thread windows error code 8 I keep getting an Windows error code 8 on my custom studies. Contrary to that user, restarting does only fix it temporarily for me.
Maybe this is connected to "sc.MaintainAdditionalChartDataArrays = 1;" ?
I currently have more than 8 GB of free RAM and 45 GB of free Disk Space. So I am unsure where the issue lies.
I send the log for analysis via the Send for Analysis function. As you can see, after the storage error occurred I am unable to save pictures too. I also double checked the Data folder file paths and that "Always Use Data Folder Within Main Folder" is checked.
Looking forward to figuring this out.
Thanks and regards
[2017-08-01 20:40:42]
No it is not.
How much memory is being used by Sierra Chart process at the time you get this error message? You can tell from the Windows Task Manager.
[2017-08-03 10:44:04]
I think this can be closed. I missed some FreeDll = 1 and I think this fixed the issue.
I am running diagnostics just in case.
Thank you
