Date/Time: Wed, 15 Jan 2025 12:52:48 +0000
bring chart to the end on x axis
View Count: 772
[2017-08-01 12:54:38]
User472677 - Posts: 356
Often inexpiably a red box shows up on the bottom right hand corner showing that the chart is not to the end. I know that I can check the pointer and drag the chart until thee box is green.
1. Sometimes the drag does not work. I end up restarting sierra. Is there a better solution?
2. Is there one command or action that can bring the chart to the end? dragging is cumbersome.
[2017-08-01 16:40:44]
You need to use Chart >> Scroll All Charts to End.
