Date/Time: Wed, 15 Jan 2025 12:40:38 +0000
Chart >> Lock Fill Space - not working
View Count: 1608
[2017-08-01 11:06:37]
User956467 - Posts: 30
Upgraded to 1590 because Chart >> Lock Fill Space was not working. Not working in 1590 either. When I check or uncheck Lock Fill Space the "L" in the lower right corner of chart does not toggle visible/not visible. The "L" is in view continuously. As well, when I check Chart >> Chart Settings >> Advanced Settings >> Lock Fill Space the check to the left of Highlight Timescales... toggles visible /not visible.
[2017-08-01 11:36:49]
Quite a few things are not working. Duplicate Chart, Chart Trade Mode etc. So, looks like the issue is at my end. What do you suggest?
[2017-08-01 19:47:38]
When you open a new chart, are you able to enable and disable Chart >> Lock Fill Space for that chart?
[2017-08-02 00:13:22]
yes, everything seems to be fine with a new chart. what does this tell you? thanks very much.
[2017-08-02 01:57:14]
This indicates that a study is enabling the Lock Fill Space option.
