Date/Time: Wed, 15 Jan 2025 12:54:16 +0000
stabilizing sub chart
View Count: 762
[2017-08-01 02:05:16] |
aydex - Posts: 110 |
Hi I wish to have the MACD chart at bottom always show the zero line as it does in screenshot I have noticed it moves around depending on the market, and often goes above or below visible range. Is there a way, when scrolling back in the timeline, to have the current price (price at point in timeline) displayed at top, and zero always show on bottom macd? http://www.sierrachart.com/image.php?Image=1501552577515.png |
[2017-08-01 04:56:53] |
You could use a User Defined Scale: Chart Scale and Scale Adjusting: Scale Range (Scale Settings) But it sounds as though you need to reset the scale if you have altered the scale with Interactive Scale Move. Refer to: Chart Scale and Scale Adjusting: Resetting the Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
