Date/Time: Sun, 24 Nov 2024 02:33:47 +0000
Compling on Windows 8.1 preview
View Count: 1878
[2013-09-02 01:53:33] |
mhren - Posts: 12 |
I was trying out the Windows 8.1 Pro preview this weekend and have found that SC runs quite well on it at least given my initial checkout ... I did run into one problem compiling my custom studies and I'm wondering if you might have some insight into how to correct this ....I started with a clean install, and installed SC version 1019. I installed the compiler from the "Build Advanced Custom Studies DLL" menu. This completed without errors. However, when attempting to compile my source, it appears that one of the includes ("map") is not available ... maybe missing with the latest compiler install or ???? The message I get is: C:\SierraChart - IB\ACS_Source\sierrachart.h:26:15: fatal error: map: No such file or directory
#include <map> ^ compilation terminated. I will dig a bit more to understand what might be missing .. but I wanted to check with you since you may have a better idea of what is included in the compiler provided through the "Install Compiler" option. I did go back to my other Windows 8.0 install but that compiler has been there for some time so I'm wondering if it's something related to the new and clean installation .... Thanks!! -- mike Date Time Of Last Edit: 2013-09-02 01:54:40
[2013-09-02 02:55:51] |
Do you see this file on your system: Drive:\SierraChart\CPPCompiler\lib\gcc\mingw32\4.7.2\include\c++\map Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-09-02 03:36:28] |
mhren - Posts: 12 |
The brand new install I have here on the Windows 8.1 system does NOT include the Drive:\SierraChart\CPPCompiler\lib\gcc\mingw32\4.7.2 directory (while my 'old' Windows 8.0 system does). It appears the new install picked up Drive:\SierraChart\CPPCompiler\lib\gcc\mingw32\4.8.1 and it does have the Drive:\SierraChart\CPPCompiler\lib\gcc\mingw32\4.8.1\include\c++\map file but possibly the build process does not include this new path ? As an aside -- this new version (4.8.1) may have nothing to do with Windows 8.1 and is just what got picked up when I installed on this new system ? Date Time Of Last Edit: 2013-09-02 03:37:53
[2013-09-03 01:06:35] |
We are testing this.
[2013-09-03 03:39:08] |
We cannot duplicate the problem. We deleted the compiler and did a fresh install. The compilation is good: -- Starting build of Custom Studies Source File: test1.cpp. -- 15:37:30
Our recommendation is to delete this folder and install the C++ compiler again:"D:\SierraChart\CPPCompiler\bin\g++.exe" "D:\DLLStudies\test1.cpp" -march=i686 -mtune=i686 -O2 -shared -static -static-libgcc -static-libstdc++ -s -fno-rtti -fno-exceptions -o "D:\data2\test1.dll" -- End of Build -- 15:37:31 Drive:\SierraChart\CPPCompiler Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-09-03 03:40:05
[2013-09-03 12:27:35] |
mhren - Posts: 12 |
I am traveling for the next day but I will delete the files and do the compiler install again when I return. Even though things are working fine on my windows 8.0 system, I will take the same steps on both systems (windows 8.0 and windows 8.1) and will let you know if this is indeed something unique to the compiler install on the new OS.
Date Time Of Last Edit: 2013-09-03 12:28:10
[2013-09-08 07:29:49] |
mhren - Posts: 12 |
Deleting the CPPCompiler directory tree and re-installing did clear up this problem for my installation on Windows 8.1 Preview.
