Date/Time: Wed, 15 Jan 2025 16:18:45 +0000
Spot FX with Forex.com
View Count: 1916
[2017-08-01 00:39:11] |
User487249 - Posts: 9 |
With FXCM now gone in the U.S., can Spot FX data and trade execution be done with a forex.com or Oanda account? Is IB the only U.S. Spot FX broker where a feed and execution can occur directly in Sierra Chart? Thanks, Daniel Date Time Of Last Edit: 2017-08-01 19:42:25
[2017-08-01 21:31:30] |
We apologize for the delay. Forex.com is Gain Capital and Forex trading is supported through their futures trading platform service which also supports cash Forex. Sierra Chart does support Gain Capital futures. Refer to: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php And Interactive Brokers is also supported: Interactive Brokers Trading Service Oanda is not supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-08-01 23:02:51] |
Thank you, Still a bit confused. If I open a futures account through their OEC, I get the forex feed, but will I be able to enter trades directly in Sierra Charts if my account is with forex.com? Or does this just provide the feed? I notice their OEC futuresonline.com offers forex accounts. If I open a forex account with them, will that allow direct execution through Sierra Chart? Thanks again, Daniel |
[2017-08-02 05:40:28] |
but will I be able to enter trades directly in Sierra Charts if my account is with forex.com? We are not sure about this. If I open a forex account with them, will that allow direct execution through Sierra Chart? Yes this is correct and we know for sure.
[2017-08-22 18:28:06] |
Thank you for the help. I have the OEC feed coming into Sierra. I am able to execute trades directly in Sierra with this method for spot FX. However, there is a small price difference when I compare the OEC feed in Sierra to their Gain Trader platform. For instance the USDJPY is consistently 1-pip difference. Could this be a bid vs ask problem? I contacted Gain and they said there should be no difference in their server data from the OEC FIX. See screenshot.
untitled.png / V - Attached On 2017-08-22 18:26:19 UTC - Size: 148.91 KB - 328 views |
[2017-08-22 19:13:44] |
Sierra_Chart charts the Bid and Ask average, and all price bars and current price for the symbol is based upon this average. Overall we have found this to deliver the best reliability with the price data from Gain Capital because otherwise we have seen some issues. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-08-22 19:14:06
