Date/Time: Wed, 15 Jan 2025 12:35:36 +0000
backtesting no longer works
View Count: 1306
[2017-07-31 16:58:26] |
User606491 - Posts: 164 |
My back test no longer return data. From the long, can you tell me what I need to change? Yes, I have my backtest setting set to "simulated account". thank you. see log below: Reading Internal Order ID file. | 2017-07-31 10:38:14 Reading Trade Orders file. | 2017-07-31 10:38:14 Reading Trade Positions file. | 2017-07-31 10:38:14 Listening on UDP port 22903. | 2017-07-31 10:38:14 Software version: 1591 | 2017-07-31 10:38:14 Usage end date: 2017-08-31 | 2017-07-31 10:38:14 Enabled for: Advanced Features. | 2017-07-31 10:38:14 Enabled for: Advanced Features 2. | 2017-07-31 10:38:14 Enabled for: Sierra Chart Historical Data Service. | 2017-07-31 10:38:14 Allow Support for Sierra Chart Data Feeds is enabled. | 2017-07-31 10:38:14 Current selected Data/Trading service: CQG FIX Trading | 2017-07-31 10:38:14 Chart Update Interval: 300 | 2017-07-31 10:38:14 Data/Trade Service Settings automatically set. | 2017-07-31 10:38:14 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2017-07-31 10:38:14 2017-07-31 10:38:22 Local computer time | 2017-07-31 10:38:14 2017-07-31 14:38:22 Local computer time in UTC | 2017-07-31 10:38:14 2017-07-31 10:38:22 Local computer time in SC Time Zone | 2017-07-31 10:38:14 2017-07-31 14:38:17 Server time in UTC | 2017-07-31 10:38:14 Local computer UTC time and Server UTC time difference: 0 seconds. | 2017-07-31 10:38:14 Program path: C:\SierraChart\ | 2017-07-31 10:38:14 Data Files path: C:\SierraChart\Data\ | 2017-07-31 10:38:14 OS Version Number: 10.0 | 2017-07-31 10:38:14 Locale Setting: C | 2017-07-31 10:38:14 Date Time Of Last Edit: 2017-07-31 18:18:17
[2017-07-31 18:18:33] |
There is nothing in this Message Log which would indicate the reason for the issue. Is is an ACSIL or Spreadsheet Trading system? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-31 18:25:14] |
its a spreadsheet. It was working fine yesterday and is now no longer working. Perhaps the only change I've made between then and now was to download the pre-release version. However, I'm not convinced that this is the cause.
[2017-07-31 18:39:01] |
The first thing to do is to follow through the instructions here for this: https://www.sierrachart.com/index.php?page=doc/SpreadsheetSystemsAlertsAndAutomatedTrading.php#IgnoredSignals (Ignored Signals With Spreadsheet Systems or Alerts) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-07-31 19:05:14] |
Auto trading enabled - global was somehow unchecked. consider this closed. as always, thank you. |
