Date/Time: Wed, 15 Jan 2025 12:44:52 +0000
Auto Scroll Charts even when no new bars appear due to filtering
View Count: 1004
[2017-07-31 09:21:52] |
traderacademie - Posts: 38 |
Hi, I've filtered the volume on some of my charts, and this has the consequence that these charts are not updating with "an empty column" if the time period goes to the next period. On charts where I didn't filter the volume, the charts update with a new bar as usual. The filtered charts only go to the next period if new (filtered) bars appear, but they will only appear if they are above a certain volume threshold. But I want the chart to scroll to the next period, even when there are no new bars appearing (due to the threshold), basically showing "an empty bar" or whitespace. Is this possible? Rgds Will |
[2017-07-31 11:25:30] |
Not at the end of the chart, unless you disable Chart >> Chart Settings >> Advanced Settings 2 >> Volume Filter >> Filter Trade Completely.
[2017-07-31 11:30:38] |
Unfortunately I don't want to display the price either and furthermore, this impacts the studies "ask/bid volume difference bars" on the charts as well, which is not what I want. So unfortunately, this is not a solution for me. Rgds Will |
