Date/Time: Wed, 15 Jan 2025 12:37:41 +0000
P&L column on trading DOM
View Count: 679
[2017-07-31 08:17:34] |
rc7rader - Posts: 144 |
Is there a setting to make the P&L column in the trading DOM show in ticks instead of points? Thanks. |
[2017-07-31 11:27:58] |
This is documented here: Chart Trading and the Chart DOM: Chart DOM Position Profit and Loss Column Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
